We do test RR on a win2000 system and are unfortunately unable to replicate this error. Can you try double clicking on the Adjust->Intensity module (instead of pressing on Insert) and see if you have the same response?
Also, try loading a smaller image, exit and then restart RoboRealm (this will load back in the small image) and try inserting a module. It is possible that the image you are using is causing some unknown error (due to its size, compression, etc). If you do notice a it working with another image could you post the one that breaks the system here?
