Sample edge crash Anonymous |
Hi, STeven
This sample edge is really fast, I can run 1190x960 at 30fps rate.
But suddenly, it crashed and I can't run it anymore.
Please see attached robo for your review.
Calvenn program.robo
Calvenn,
We tried at a 1280x960 resolution for about 10 minutes with your script and everything seems to work.
Can you try running RR while holding down the CTRL key which will bring up the program in a default config with no camera. Then try to activate the camera again and load in your script. Let us know if you see this happen again.
If so try to remove modules until the system becomes stable. Let us know which module it is that when added causes the crash and we will look into it further.
