Camera
Is there any suggestions in cameras that would work best for vision based software that has high resolutions with fast frame rates?
Anonymous 19 year
That's a difficult question to answer without knowing more about your intended application. We specialize in less expensive webcam type cameras that can achieve about 30 fps. We also have one that can do about 50 fps (Philips SPC 900NC) but the camera frame rate is normally not relevant as the processing of the images will very quickly slow down the possible frame rate unless you have some very serious computing power or are doing the simplest of processing.
Also note that webcams are typically used with 320x240 or 640x480 resolution. We do have one that will do 1280X960 but the frame rate then really slows < 7 fps (Logitech Fusion).
