Accessing markers through API C++
Sudzzz from United States  [17 posts]
I've a couple of errors trying to access markers through RR's API server in C++.
Heres my code. I have a marker Fill whose image output I would like to save.
if (rr.getImage("Fill", image, &width, &height, 320*240*3))
        if (width*height*3>1280*1024*3)
            printf("Fill image width/height error!");
            exit(0);
        printf("Getting and saving image from Fill marker.\n");
        rr.savePPM("D:\\UP\\RoboRealm\\API\\testfill.ppm \n", image, width, height);
Error : Run-Time Check Failure #3 - The variable 'len' is being used without being defined.
Sudzzz,
It looks like your compiler is complaining about a used variable 'len' without it being initialized. There is no len defined in the code that you pasted so the error is possibly somewhere else. Can you include the line number and source code of the line that the error is being generated from?
Alternatively, just initialize the len variable where it is defined. For example
int len;
should instead be
int len=0;
