Typically when we need something to process at a much faster rate a module will run independently of the pipeline to process incoming data (for example the serial module does this) instead of requiring the pipeline to run at the needed polling speed.
So modules that do this will buffer the data to be processed once the pipeline does execute the module.
While it is possible to get 90FPS this will really depend on your system configuration, USB (or ethernet) speed and which modules you have running.
Perhaps you can help us understand the need for this higher frequency?
