You mentioned a different solution on another thread (loading in actual image digits as needed) but in case you want another method I'd try using FormatNumber.
which should set the variable with 2 decimal places. Once SetVariable runs the "number" will be interpreted as a string and should show using DisplayVariable as a 2 digit decimal number even with a zero.
