We've not done a project like that before so you would have to find someone to help you understand those papers and implement a similar technique. Please keep in mind that research projects are typically done in ideal settings so quite a bit of work is needed in order to turn research results into a reliable and workable solution.
At least the links you mention will provide some examples. You will need to create a large database (at least 500 samples) in order to know that the techniques work for you. Because your lighting and types of wood might differ from the research papers, you may find that other techniques work better. A lot of experimental work is required.
