Probably the most convienent way is to use the Blob Filter module and select the Create Blobs Array which will create an array of X,Y coordinates. The reason I suggest the blob filter module to do this is that you will probably want to use it to filter out any small blobs or blobs that you don't want to track anyhow. From here you can use one of the programming modules to execute your above conditional array using the GetArrayVariable("BLOBS").
