before that line. Plus, if you don't have that array in RR then it will error since the array will not be created. I've attached a small robofile that does create that array just for testing. We have also updated the example program download (API.zip) to include a ubound check which is needed to check if the array has actually been filled with anything which is needed in VB. Note, the examples are meant to be very simple so not all checks are done.
Dim myListX() As Object
rr.GetIntArrayVariable("BLOB_LABEL_X", myListX) 'myListX and myListY are null
If IsArray(myListX) Then
If UBound(myListX) > 0 Then
MsgBox(CStr(myListX(0)))
End If
End If
