touchscreen
ezecor  [1 posts]
HI, im trying to make a touchscreen interface, and i wonder if it is possible to use two cameras to simulate a click when an object is detected (one camera for x, and the other for y). It is possible in RoboRealm?
sorry my english i hope you understand what im trying to say :)
Yes! It is possible. While we have thought about a similar configuration to the one in your image we've not actually implemented it. However, RR is very capable of processing multiple cameras in succession. You can use the "Other->Marker" module to switch from one image to the next. Thus, you would start with one image, process it for the X location, save that in a variable, use the marker to switch to the other image and process that for the Y. At the end of the loop you'd have the X and Y locations.
Should work quite nicely! Let us know if you need any additional help with the processing. Please include images if you can.
